I have an X320 with rear tire size 22x11 - 10" rim. Got a nice puncture in the sidewall. Anyway, I'm having some difficulty with trying to find an inner tube. JD dealer says that the tube for that tire is a 20x8 - 10" rim. Seems like a long way to stretch, if you ask me, but I bought it. Well now the tire, with the tube, has a different profile than the non-tubed tire.
The tubed tire has more of a rounded shape to the tread. The non-tubed tire tread is flat. So even if I get another tube for the other tire, then both tires wont have as much contact with the ground. Not that big a deal for everyday mowing, but for slopes or for use on snow covered pavement could be a problem.
Anyone else run into this? Should I try an find an ATV inner tube of the correct size? Even the parts breakdown, for my tractor, lists the inner tube as part number M150317 which turns out to be a 20x8 - 10" rim.
