1 - 3 of 3 Posts
i have a 1979 ford 2600 diesel it starts fine when its cold but after you run it awhile and kill it . it will not start unless you use ether someone said the injector pump was weak . is it hard to rebuild the pump or is it best left to the experts. i can work on gas engines but have never tried diesels any suggestions will help
You need to take the pump to a shop that have the machines to calibrate it for flow and pressure. Would not hurt to have the injectors checked at the same time for a general all round tune up.
1 - 3 of 3 Posts
