917.250520, Kohler Magnum MV20S-57529 19.5HP
I may have inherited a ~'95 GT6000 that my dad got used off the curb at Sears years ago.
Long story short, he has had a mechanic work on it for years, changing from mower deck to snowblower, tune-ups, repairs, etc. In the last month, this mechanic told him the motor is shot, nothing he can do except try a new fuel pump but he thinks the crankcase is letting air in somewhere, causing it to not stay running when hot. He ordered the fuel pump, 1-2 weeks later installed it and no change. My dad started offering it to friends, and I quickly stopped him and let him know I'd take it if only for the snowblower.
So everyone else he offered it to said they couldn't use it (for parts, repair, etc.), so I went out to take a look today, being next in line. I had it running fine within 5 minutes, and didn't really know what I had done.
Previous symptoms:
1. Would not start or run without full choke.
2. Sounded rough while running.
3. Loss of power after a few minutes of running
So my Google searches led me to believe it had to do with the carburetor, so I started there. Took off the entire air filter assembly, turned the key and it fired right up without opening the choke. I ran it for almost 45 minutes and ran around and mowed a bit during that time (it was not at all dusty out and I avoided tall grass or pollen areas since the air intake was unfiltered).
By this time my dad got back to his house, saw I was out in the yard, and said it would never have run that long. So I shut it down, started reassembly. I got the air filter box back on, and it sounded absolutely terrible. Checked out what had changed, and found the right side (facing tractor front) spark plug wire was pinching one of the throttle toggle pieces that's spring loaded. It wasn't that tight, but the spring couldn't overcome the pressure of the cable resting overtop. So I re-routed the spark plug wire, and the tractor fires up right away and sounds normal with NO choke, something it's never done as long as he's owned it.
So my question here is, should I do any carb rebuild or other engine overhauls before using it for blowing this winter? I plan on doing an oil change and seeing about the hydraulic pump or transaxle to get the hydrostatic to work a bit better. Other than a full break down and reassembly, is there any way to test the crankcase for leaks like the mechanic diagnosed? I can do a compression test as well. I guess my major concern is that even though it seemed like a simple fix, and it sounds "decent" now, it's getting older. I don't think there was much to what the mechanic said, but you never know. I'm hoping I corrected something that's been a hidden problem for a while.
Previous symptoms:
