1 - 3 of 3 Posts
I recently got a ingersoll 448 with the built in holding valve and i am having a problem where it lunges on the down hill in forward if you downhill in revers it is perfect all linkgages are tight no slop at sll i have cleaned hllding valve and replave the oil with rotella 15w40 any help os greatly appreciated
On a wild hair. When you cleaned the holding valve, did you unscrew both ends and clean the inside of the sliding spool and checked the 2 balls in there?
I did not is that something i should do
1 - 3 of 3 Posts
