1 - 1 of 1 Posts
I just picked up a 3012 it didn't appear to be pumping gas took the carb off took the fuel pump off cleaned everything reinstalled and it took off let it run for about a half hour shut it down put all the covers back on went to take it for a test run just about the time I put it in gear it stalled out took it out of gear tried to restart acting the same again like it was not getting gas pull the hose off the pump turn the key it is pumping gas pulled the bowl off the carburetor it is filled with gas it will start with a Blas of starting fluid but will not stay running any suggestions
1 - 1 of 1 Posts
