They are hydraulic drive and were powered with a 16 HP Onan. Great tractors.
I suggest you go to the Ingersoll site, http://www.ingersolltractors.com/, and read up on the new tractors because they are, with respect to the drive train and major components, the same as the ones built by Case going back to the early 70's. The hydraulic drive is the centerpiece of the their design and is unique in the garden tractor world. One of the major benefits is that many attachments such as tillers, logsplitter, leaf vacs and others can be run directly off the tractor hydraulics. The other major benefit is that they are incredibly rugged and reliable since many of the components prone to failure in other tractors don't exist on these. The other good news is that since the design has remained virtually unchanged you can still purchase most parts new through any Ingersoll dealer.Thanks for any info I can get on this case
If it doesn't have the added valve you could always add one, or read the owners manual on how to use the retard feature.fry,
only issue, is if you live on a hill side, the hyd drive system will free wheel down the hill.
Case did make sometype valve that would eliminate this concern.
Flat yard or climbing a hill they are great.
Just a heads up.
Bahh! Holding valves are for wusses. Look out.. Weeeeee!!! Seriously though, down-hill is controllable on the oldies. You've just got to be on your A-game, read the recommendations here and in your manual. Oh.. functioning brakes help too.
Joel
But KEEP the hydraulic pressure up by keeping the throttle near wide open. And remember that putting it all the way into reverse may put you into an uncontrollable skid! Use the "retard" according to the owners manual!The 446 has no brakes except for a parking brake. If you step on it while traveling it will throw it in neutral and still won't stop it. Just pull back on the travel control. You can go all the way into reverse if need be.
In your thread, you said that you got the Operator's Manual with this tractor. Did you not read it??"Retard" feature:
Apply named feature as that is exactly what I felt like as was picking up speed and rolling down the hill pumping the "brake".
How does one go about installing the valve to correct this? I only have so many pairs of work pants at my disposal to soil!
When this happens don't forget to holler "wweeeeeee...""Retard" feature:
Oh, I was hollering something alright. But it wasn't "weeee" and I'm pretty sure it would violate the vulgarity policy on this sight :0When this happens don't forget to holler "wweeeeeee..."![]()
Seriously though its happened to me more than I care to admit. My entire barn area is on a giant hill and the barn area is level and landscaped with big boulders and many trees are also present.
If it does get away from you don't panic, just ride it out and don't run anyone over or hit anything.
