1 - 3 of 3 Posts
Hi everybody,
Thought i would thow it out there about a problem with my new (old) case 446 with replacement Inamar 18 hp. Occasionally when i try to start it it doesnt even crank. If i walk away and come back it eventually will crank and start. At first i thought it was a weak battery cause it cranks kinda weird too. Almost like when a starter is hot or the timing is wrong. But i think it might be more than that. On the repair slip that came with the motor i see the ignition was replaced along with the engine back in 02. I hate replacing parts trying to find the culprit.
Any ideas :thanku:
1 - 3 of 3 Posts
