I think the original one is 160-180 maybe?![]()
Carburetor Carb for 16 hp Engine series number 303777 with Nikki 696353 | eBay
A minor difference in carburetor design may result in a different model. Send us model numbers & pictures of your current carb with clear shots on each side, we can help find a right match for you. 1 x Carburetor Kit as Pictured.www.ebay.com
No idea if it is any good. Many people have had good luck with inexpensive carbs. It appears easy to find one online for not a lot of money.
I bought a cheap one for my Stihl saw and it runs too rich. It did work okay when I first got it, but not do much now a few months later. The original one lasted over a decade, until the diaphragm stopped working.
It looks like the original carb for your engine is still available, but is probably twice the price.
JMT ENT. | PO Box 183 | 443-542-1526 | [email protected] |
Barton, MD 21521-0183 |
Sounds like the needle wouldn't close originally and now it won't open. I usually got them to run but would be lean or right and I learned about how to clean the pilot jet, the nozzle, etc.Thanks. The main problem is the mounting with the online ones. The ones that match, mount differently therefore, won't work. This one is 4 bolt mount.
I put a new fuel pump on it and gas flow is good to Carb.
The Mower sat for 9 years. The owner died and I got it off of a relative. It actually started and ran for about 20 minutes when i got it. Gas was overflowing out of the choke . Cleaned carb. Put needle. Mower never started again unless primered Then would die after primer burned out.
Jets may of got grimed up as old gas ran thru them when it started. Ive used carb cleaner over and over. What did u do to clean them ?Sounds like the needle wouldn't close originally and now it won't open. I usually got them to run but would be lean or right and I learned about how to clean the pilot jet, the nozzle, etc.
The parts for them are so darn expensive and normally not stocked most places so a bowl gasket and a needle comes out to almost $50.
This is what you really needJets may of got grimed up as old gas ran thru them when it started. Ive used carb cleaner over and over. What did u do to clean them ?
Don't forget carburetor screwdrivers! For unscrewing jets, nozzles, and emulsion tubesThis is what you really need
Thanks man ! Actually found a carb match. Supposed to be here 2morrow. Hopefully, it works.Don't forget carburetor screwdrivers! For unscrewing jets, nozzles, and emulsion tubes
