1 - 2 of 2 Posts
I'm trying to locate a used 15 amp stator for my Kohler CV16. Right now the stator is only producing 14 VAC at full throttle (and not the 28+ VAC as expected). If you know of any merchants or if any of you have one and are willing to part with it, please let me know. List price for these guys is between $60~$80. yikes!
Thanks.
Joe
Discussion Starter · #2 ·
It was the flywheel magnets, not the stator
It turned out be to be a bad repair job from the previous owner on the flywheel magnets that was causing my voltage drop. Upon inspection, I noticed that two magnets on the flywheel had been re-glued. The problem was that the magnets were not glued back in proper [N-S-N] [S-N-S] orientation. I had to crack both magnets off and JBWeld them back in proper orientation. Now I am getting 30 VAC at full throttle.
1 - 2 of 2 Posts
