I have several implements for my BX25, including a tiller, a landscape rake, and a box scraper. I have a nice size pole building to store it all in, with a good concrete floor. My problem is moving the implements around without having to give each one wall space. So if the implements are two deep, (rake in front of the tiller, for example), I have to move the rake to get to the tiller. That means hooking up a chain and lifting it out of the way to get to the tiller. Anyway, I got this idea that I could use pallets for storing the implements (just set them down on a pallet and then disconnect from the 3ph). Then I could just use a pallet jack (less than $200) to move them around easily. I thought that might give me good maneuverability without having to put the forks on the tractor and move stuff that way (although that would also be a possibility).
Would connecting implements to the 3ph when sitting on a pallet be any different from doing it with the implement sitting on the floor? Just wondering if this might be a way to make my storage more fluid and make implements more accessible without a hassle.
