1 - 2 of 2 Posts
Has anyone had a problem with a tractor popping back through the intake. But there is nothing wrong with its head? The card has been rebuilt, professionally. Everything in it is new. New plugs and wires. Put a new coil on it. No new points or condenser, new fuel pump.
Verify that the firing order is correct, and then, remove the valve cover and make sure all the exhaust valves are moving all the way. If not, you have a flat cam lobe.
1 - 2 of 2 Posts
