1969 MF 135 with perkins
they sell a resistor, and the new coil I got came with one, what is the purpose of it?
The trouble I am having is a transient power loss, I think its in the electrical system , sometimes it goes away when it is warmed up other times it works just fine.
I am changing the coil and wires, already have done the points and condenser, new wire from ignition to coil. I have never had a resistor on the coil in the last 30 years since I got it. The last time this happened I thought it was gas and replaced the carb. and it did the same thing for a while , then it started running fine and has been for three years. BUT sometimes when it runs a while it will stall out, usually when its hotter out. then when it cools down it runs fine, I have heard that, that might be the coil
this time it was running well getting time for a tune up. but also have been fighting a burn spot on the starter winding, so I decided to replace the starter, that went well, changed the points cond, and started having trouble again,.
I was getting plugs fouling, so I changed them, and this is why I think that its ignition. I also used a strobe light to get the timing, but it was not a steady blinking, but all jerky , this is leading me to think I have some problem with ignition.
thought it might be the ign wire shorting out so I change it also.
I just got the new coil and will try that out.
if you have any clues I would appreciate and suggestions. I use the tractor all the time and its a nuisance when it is not working well
