Hello all, I am having some ignition switch issues and need a little help. The old switch would work to start tractor but would not shut it off, weird I thought, so I bought a new one and it is doing the same thing, the switch is a #365402, a 5 male prong type for an older Craftsman 2 tractor. Can anyone tell me if I got a new switch that is bad also or tell me a possible way to test switch to see if it is indeed bad,or could there be another possible problem? I did check the ground wire coming off of pigtail connector that goes to side of frame and it is good and tight. Don't know much about tractors so I figure I would ask before spending any more cash. Any info will be appreciated, Thank you.
