Idler Pulley, and spacer size
512 Views 3 Replies 3 Participants Last post by  jd110
Hello all. I need help to determine the correct size/part number for the deck idler pulleys and the spacer on a John Deere 46" deck tractor model 260/265. Thanks!
Try looking on the jd site
I have used the parts diagrams to figure out assemblies
You can cart the part and have the actual part number needed
RoadrunnerII
Sent from my SM-A515F using Tapatalk
Look up the tractor then look for the correct deck under the tractor
RoadrunnerII
Idler pulleys are AM37249 and spacer under pulleys are AM40509 along with a 24H1351 washer. .
