1 - 14 of 14 Posts
I have been browsing around here and found out the builder of my Dayton is MTD and am trying to find a model number of my store brand m ower.
I will get pictures up tonight but here are some details. it is a Dayton with a 16 HP briggs and stratton, has a 4speed manual, I think it is a 46 inch deck ( has 2 22 inch blades and a smaller third one) has no auxillary PTO or 3 point hook ups that I see. Also has the square headlights. The model that is printed is 3Z715C-E0630.
I need to get serveice parts for this mower at this time and the shops around here do not know what a Dayton is. So i am trying to find the MTD equivalent to order parts.
Matthew
Okay so pictures will be posted tonight but the info from the link to Jacks small engines and the data I pulled off the engine the code is 81111712 so it is an 81 if I read right. I did not think this one was that old. But as I said pics tonight.
Deere 330 Killer
looks like the rims are on inside out?
Murray tractor owner
Looks like a 800 series GT, For parts just go to a dealer and tell them you have a MTD the give them model and serial number and then they can find parts for it.
Finally at 1k!
Ya, the frame is the same as mine.
Discussion Starter · #9 ·
HUGH SS/16 you know I always wondered why the valve stems are on the inside of the wheel maybe this is why.
So far a lot of the repair shops here have not been able to figure out the model number on this one. I guess it is a grainger number instead of a standard MTD model number.
It has been a good mower for me for the last two years my biggest problem is it has stripped the steering gear in the left turn direction. I just need to source a gear for it and this one would be set.
Matthew
Matthew
go to partstree.com and type in your model number it will give you all the parts and the part numbers.
It looks like you and I have the same tractor. have you been able to find any information on it? I just bought mine, and the only thing different is the color. Mine is the burnt gold color.
Patrick
i have the same tractor, it is tough as nails, my only complaints are the stamped steel front axle ( mine is getting replaced with cast iron)
and the bolted frame. ( mine is getting reinforced)
other then that, it's great.
the wheels are not backwards there reversible, for plowing,
pulled a couple small stumps with mine last summer,
btw:the rod at the back,holding the gas tank in, it's for a sleeve hitch.
your mower is the same design as my 1985 lgt-1610 white lawn tractor. model no. 145-822-190 . 1980 ranch king same also. mower deck is 2 blade side discharge 44inch cog belt timed. model no. 195-935-190 steering shaft pinon gear is part no. 948-0237 sector steering gear is 748-0236 sector gear shaft bushings 941-0490 . my original mower deck rusted out. converted murrys 46 inch deck to it, but original one sucked grass up better. mtd parts co. 1-800-800-7310 ph. no. can get you parts
did you notice how old this thread is?
Interestingly I got an 814 with no deck and tried to run a 39" murray/noma deck but didn't realize it and used the 5/8 belt and the tractor pulley was made for 1/2 mtd belt. I broke the pulley. I finally got the correct 44" deck and was able to weld up the pulley.
1 - 14 of 14 Posts
