I think I read that the zerk fittings on the mower deck should be done after every ten hours of mower? Does that sound right?
She looks nice a clean in the pics!
Here are my maintenance notes for the i1050, your needs might vary slightly due to model differences. Most of this came right out of the owners manual, some from suggestions on MTF. I found it easier to follow in summarized form.
Deck spindle lube is shown as every 10 hours. I do it every time i take the deck off to clean the underside, which tends to be less than 10 hours.
Cub i1050 maintenance:
Oil
change oil and filter every 100 hours
use wt - Below 32*F: 5w20, 5w30, Above 0*F: 10w30
lube
Use Cub 251H EP grease or #2 lithium
lube spots:
Every 10 hrs of mowing:
- deck spindles
- deck idler bracket
Every 25 hrs:
- front wheel bearings
- steering axle pivot bars
- steering arms (see manual p.22)
- steering gears and linkage
Every 50 hrs
- deck front ball wheels
Once a season
- rear axles and rims (w all-purpose grease)
- all pivot points and linkages (w light oil)
Tires
rear: 10psi. Front: 14 psi. 25 psi max any.
Deck
spindle bolt torque: 70-90 ftlb
cooling
Blower housing and cooling shrouds: clean every 100 hrs.
hydros
sealed - no maint (!)
Belts
Trans drive belt: have dealer do. Req's removing linkage and readjust.
Deck belt
plugs
regap (.030 in / 0.76 mm) or replace every 100 hrs
torque to: 18-22 ft lbs
air filter ("pre cleaner")
wash and reoil (engine oil) every 25 hrs (or more if dusty)
replace every 100 hrs or annually
paper element: check every 50 hrs, replace 100 hrs or annually
fuel filter - check every 100 hrs.
Battery charging
- min 1 hr at 6 amps, do in ventilated area
Mow blades
Sharpen frequently
Make sure tips align with adjacent blades, both ends
