... We can't save them all.
The main issue I have is the HYDRO. When in low or high range,you only have two choices when pushing the lever, it's... GO and GO a little faster .
To be honest, I don't understand this statement. If your tractor is working properly, then you should have a smooth transition from dead stop to full travel speed no matter which range you are in. I've driven hydrostatic tractors as well as the Case hydraulic drive tractors and while there is some difference in feel, both are capable of applying power and speed to the ground incrementally. If you are not experiencing full control over your ground speed, then something is wrong with your tractor that is repairable.The main issue I have is the HYDRO. When in low or high range,you only have two choices when pushing the lever, it's... GO and GO a little faster .
:Stop: Are you suggesting that Deere's are "creepy"? :sidelaughIf all linkages are tight (no slop) you should have the choice of creeping along just like your Deere
just their owners....:biglaugh::Stop: Are you suggesting that Deere's are "creepy"? :sidelaugh
In low range in with the speed control lever in the fast position at 1/2 throttle the tractor will stop when going up a slight hill . Open it up to WOT and it starts to go up. The oil tank is 3/4 -full. The engine doesn't boog or lug at all.To be honest, I don't understand this statement. If your tractor is working properly, then you should have a smooth transition from dead stop to full travel speed no matter which range you are in. I've driven hydrostatic tractors as well as the Case hydraulic drive tractors and while there is some difference in feel, both are capable of applying power and speed to the ground incrementally. If you are not experiencing full control over your ground speed, then something is wrong with your tractor that is repairable.
If you have not drained the hydraulic system and refilled it with 20W50 motor oil, then that's where you start with the diagnosis.In low range in with the speed control lever in the fast position at 1/2 throttle the tractor will stop when going up a slight hill . Open it up to WOT and it starts to go up. The oil tank is 3/4 -full. The engine doesn't boog or lug at all.
What do you think the problem is?
IMO the best & safest way to drain the hydraulic system is to remove the sparkplug wire(s) and ground them out. Then after removing the clean 1/4" NPT allen plug, spin the engine over in short 2-3 second cranks until it stops pumping out. Let it self drain after that for an hour or so. Replace the plug with a minut amount of anti-seeze on the threads. 20W-50 may be too heavy for your NY climate so 15W-40 may be a better choice for all weather use. :fing32:I didn't receive the tech manual from the PO yet. What is the procedure for changing the oil in the Hydro ?
