I have a chance to pick up a cab, blower, weights and chains
2497 Views 13 Replies 6 Participants Last post by  Ariens93GT20
A guy 3.5 hrs from me has a cab, snowblower, weights, and chains for sale. His is a Sierra 1648H, I have a Grand Sierra 2200. I would really like the soft cab for my Grand Sierra. Does anybody know if it will fit? I can't seem to find much on the Sierra 1648H. The price is right, but it's a long drive if the stuff isn't compatible with my machine. I already have a blower, weights and chains, so the real draw is the cab.
1 - 14 of 14 Posts
You could probably make the cab work but the 1648 is a vertical shaft engine lawn tractor with a 36" belt drive blower and 8"x 20 rear tires so about all you'd get from it that would be useful on your tractor would be the cab and it's probably not exactly plug and play.
I have to agree with rneal55555. Two different tractors other than name. Search the threads I have posted the cab information for the GTs before. Should be the same for your Grand Sierra or real close. If you can not find them send me a pm.
See the Ariens GT soft cab on page 5 should have everything needed to make a decision. But I would request more pictures of that cab before driving 3.5 hours.
Well, I considered the options, and decided that for the price I couldn't get hurt too bad. Made the 7 hour round trip. Here is a pic of the cab "test fitted" on my Grand Sierra. Yes there will need to be tweeks, but I think it will be workable.
That looks real good on there, and when the snow needs moving and the wind is blowing, that will certainly be worth its weight in gold.
:ditto:
Looks like some tucks here and there. Hopefully the doors open from the front. How are the hard mounts looking?
The rear mounts fit under the seat, I will need to drill 2 holes in the fender pan to attach those. The front stationary upright mounts attach to the footrests nicely. There are two shorter front mount pieces that I will need to make replacements for, as they need to go to the front of the footrest (my best guess) They don't work that way as they are. There is one crossmember that I cannot figure out where it is supposed to go, I am waiting to get everything else secured before deciding if I need to make something for that. The doors are rear opening, and currently hit the lower fenders, so will need some reshaping. But all in all, I was quite happy with the original fit.
Does the cab have an Ariens part number? Any upholstery shop would be able to make the modes to the canvas once the frame work is gone. We have a canvas shop close by. If you can find one it may also be worth a try.
Myself I have an old Singer machine that gets used for upholstery. The metal should not be hard to reshape.
I haven't found any part number yet. I didn't have time the last couple days to spend much time on it. I broke the snowblower on my old John Deere 212 in the last snowfall we got, so I have been concentrating on that. Got the Deer snowblower finished today, and did some snow cleanup at the property I use the Deere 212 at. I used the Grand Sierra with the cab as it is a couple of times, sort of discovering changes I want before I finish locking down the installation. I'm trying to keep a tractor at each property, to avoid having to load and haul them from spot to spot.
Update: Even though it is functional, it was not an absolutely correct fit. Runagun pointed out to me that there was a cab actually FOR a GS2200 for sale about 3 hours away from me, so I picked that up as well. I was talking with a co-worker, and it turns out he has an Ariens that the snowblower and cab were meant for, so I sold it to him. I made enough to cover my cost of going to pick it up, and he is letting me keep the cab to use for the winter, so I don't have to go through the hassle of swapping in an unheated shed. I'm happy with that deal, and next year I have the correct cab.
Sounds like you came out with everything you need, a good deal all the way around!
I seen to be living in the wrong neck of the woods. I have more Ariens garden tractors in my back yard than I have seen any where. Including my local dealer that keeps telling me that they are out there some where.
1 - 14 of 14 Posts
