1 - 7 of 7 Posts
I’m using two case 223 rear ends and a 13 hp Honda engine how many gallen per min hydraulic pump do I need to run both 223 rear ends and hydraulic cylinder for steering
Power steering usually consumes 1.5 to 2 GPM depends on the controller. I use 1.5 GPM and JD 400 'power assist' controller: Power Steering Added to 646a
Most people that build articulating tractors run both geo-roller motors in series. So 8 - 10 GPM. CCI 222's originally had 8.5 GPM pumps in them and later went to a 9.5 GPM pump. Which that 13 HP honda is going to be hard pressed to drive to capacity with the necessary relief setting of 2100 PSI . Calculator I use: Hydraulic Pump Calculations - Womack Machine Supply Company says 14 HP for 2100 PSI at 9.5 GPM. Add the flow for 1.5 gpm at 1500 PSi for the power steer, that's another 1.57 HP.... Sooooo
  • Like
Reactions: PA318Guy
Hi Bigman22 and
2493790
...sounds like an interesting project...show us some pictures as you progress
ADMINISTRATOR
Welcome to MTF, looking forward to your project.
Bigman22
Welcome to MTF
Better check your facts CASE never made 223 but they did build 222 and 224's
Must of hit the wrong key, right
Why not a Onan engine probably way better then a Honda engine
BIG
You are correct. It just needs to be kept in mind that maximum performance is only achieved at maximum speed when climbing a steep slope while pulling a heavy load. At most other times, the wheels will spin before there is a max load on the hydraulics.
1 - 7 of 7 Posts
