1 - 1 of 1 Posts
Precision Application
Hypro Pumps
As the central focus of the liquid system on equipment, the pump serves a vital role. Selecting the right pump is a key decision. Often there are several pumps that will do the job right. Understanding the various types of Hypro pumps will help you make the best selection for you particular application and spraying equipment.
Hypro offers six types of pumps: centrifugal pumps, diaphragm pumps, piston pumps, plunger pumps, roller pumps, transfer pump.
Hypro centrifugal pumps are the best choice for chemical spraying and transfer applications. The Hypro line includes centrifugal pumps with housings of cast iron, polypropylene and stainless steel, all of which stand up to the harshest chemical herbicides.
The most complete selection of pumps for pumping and spraying herbicides, liquid fertilizers and pesticides is the Hypro line of diaphragm pumps. Features and benefits include low-cost maintenance, wear-free operation, wide range of flows and pressures, and long life.
Used in a range of pressure cleaning, spraying and hydrostatic testing applications Hypro’s heavy-duty piston pumps are the choice for handling fluids such as water and general use chemicals. Hypro piston pumps are constructed from cast iron materials and available in a wide range of flow and pressure ranges.
Designed for the car wash industry, Hypro plunger pumps provide high reliability and increased pressure. These pumps are developed for fast and easy maintenance, and will substantially improve efficiency and bottom line.
The leading choice of farmers around the world, Hypro roller pumps are extremely versatile. Roller pumps feature an initial low cost, are self priming and adaptable. Specific materials can be specified for casting, seals and rollers to provide compatibility with various fertilizers, herbicides, fungicides, and fertilizers.
Handle high capacity liquid transfer with ease by Hypro transfer pumps. These self-priming centrifugal pumps are ideal for liquid fertilizers, water, and any chemicals compatible with pump materials. Hydro transfer pumps are an excellent choice for improving efficiency.
1 - 1 of 1 Posts
