Hello New guy here from WI . I found your forum looking for 990 info .I have 3 of them . I bought 1 with a loader on it to help with a construction project back in 2007 . Fell in love with it . Found another the next year for parts but it ran so good I ended up repainting it and the snow plow that came with it .This week I found one on craigs . It was in the backround of a picture with a full size tractor he was selling ..Yup talked him into selling it with a tiller ..L.O.L..i Plan on freshening up the loader and my New old one this spring .
I down loaded 2 manuals on these . My one with the plow was getting just a little slow in forward but seemed the same speed in reverse . I put a new filter on then changed the Hydro fluid .I put 20 weight in her .Now I noticed a difference in the manuals .One says type F ONLY ..Others says 20 weight . The other was the dip sticks . One manual says fill up to the flat spot on the stick . Other says 1/2 way or so up the stick .
My loader was always in the flat spot and worked fine .The Plow one was kinda noisy when filled to the same area after I changed it so I slowly added and kept trying it .About a inch and 1/2 above the flat area it quit complaining and quieted down .So am I ok or over filled ?? I also want to change out the new one with the tiller .Did they change the dip stick , The hydro unit ? Miss Print in manual ?
I saw on here some guys run Hygard . Ive used it in the past on other machines . I actually use it in my Camaro with a Built TH350 tranny .Its stayed together under some rought high horse power use ..Was wondering about semi synthitic 5/20 weight oil for colder Wisconsin plowing ?
Thanks and please excuse my spelling . Its late here ...L.O.L..Larry
