Thanks for the input have not mounted the tank or pump. Planing on putting the pump in front of engine , the tank some place behind the seat where I now have a battery mounted .May put bat back under the hood ,but have a spool valve there for the plow angel set up.
Can not use the posts for tanks ,they sit in a saddel and have a pin in them to hold them down.Pull the pins and they lift off.
Use a car battery instead of a tractor battery,to big to go back under hood.
