1 - 7 of 7 Posts
I have an 812 with hydrolic,s and the pump does not seem to work the res. is full what should i look for?
Thanks John:praying:
The problem turned out to be a stuck valve the pump worked fine, but I had never worked on one before so I was not sure what to look for and this was a new tractor to me so I did not even know where to start.
John
Yes then i had a little accident with it when i was loading it up and smashed the flywheel that was not a good day. So luckly i had another 812 that i could use for parts and spent this after noon changing motors.
Can you ever have to many parts hanging around?
Gravely bug bit.
Let me think on that question a bit.
No! :D
1 - 7 of 7 Posts
