Well after 250 hours of absolutely zero leeks I finally had one happen. I just hit right at 250 hrs and had just finished a 2 hr full-power lawn mowing in 2WD. I put it in the garage and got off to notice a pretty fast drip of hydro fluid coming out of a bolt on the bottom of the rear differential directly behind the filter facing straight down towards the ground. It's not the drain plug but I'm not sure what that bolt is even there for. It must have just started when I caught it as the loss on my concrete was only about a table spoon worth & the level is still good in the sight glass.
When I checked, the bolt was slightly loose so I turned it back to snug, not hugely tighten down, just snugged up as I didn't want to strip the housing. I have run it since but havn't gotten it hot yet---no leaks so far.
Couple of questions:
1) Anyone else seen this from that bolt?
2) What does that bolt hold or do?
