The hydrostatic transmission is separate from the differential. Each is sealed and has separate fluids (heavier weight for the diff... the hydro uses motor oil).
Luckily, I have tech manual on my jump-drive.
Here's the short version...
Remove the mowing deck.
Differential
- drain
- replace drain plug
- fill with 0.7L (1.5 pt) of SAE 90 into upper fill plug (front of diff)
- oil should be a short distance below the fill hole
- replace fill plug
Hydro
- clean off transmission to prevent contamination (requires removal of fender deck and fuel tank, etc.)
- drain (I assume there's a drain plug on the bottom)
- remove vent plug beside reservoir
- add new oil (SAE 30) until oil appears at vent
- rotate input & output shafts to release trapped air
- add more oil until oil reappears at vent
In my 165 hydro there are 2 drain plugs for the hydro and transmission. I drained both but cannot find the filler for the 90w oil? I’ve already filled 30w oil for the hydro.The hydrostatic transmission is separate from the differential. Each is sealed and has separate fluids (heavier weight for the diff... the hydro uses motor oil).
Differential
- drain
- replace fill plug
Hydro
- reinstall vent plug
- fill to 140mm below reservoir top (full mark).
Good luck - JMJ
What I meant was I don’t know where the differential oil 90w goes. Can’t find where to fill it?In my 165 hydro there are 2 drain plugs for the hydro and transmission. I drained both but cannot find the filler for the 90w oil? I’ve already filled 30w oil for the hydro.
