Ya all you would have to do is disconnect the return line coming out of the valve and add a short hose to the second valve and then connect the return line to the second valve. As for the lines coming out of the second valve you will have to use quick connects so you can disconnect the scoop. Here is a link to the hydraulic connecters. http://www.farmandfleet.com/products/037740-1_2_connect_under_pressure_hyd_coupler.html?lref=%2fcatalog%2ffind.aspx%3ft%3dhydraulics%26m%3dP%26c%3dAll%2bProducts%252f%252f%252f%252fUserSearch1%253dhydraulics%26p%3d1 As for the pump if there isnt anything wrong with the one on the tractor now you dont need to worry about it. Another option is to simply replace the original valve with a double spool valve.
