Hello group. New to the forum. New to JD ownership. 1988 JD 420 tractor. Having problems with the control valve used to raise and lower snow blower attachment.
When I first got the tractor this summer, I noticed whether running or not, the lever control to raise and lower front snow blower would travel from the neutral position to UP and return just fine. It would NOT move to the down position. At the time, I ignored it, as I was busy mowing grass, not plowing snow.
This fall, I attached the snow blower and found the same problem. This time, I was a little more forceful with the control leaver and it seemed to "free up" and work OK, although it still did not move as freely as the other two control levers.
Unit sat idle for about 6 weeks. Then back to same old problem - lever would move to UP, but not to DOWN. Again I got a little forceful. This time, the control valve went into the DOWN position and stayed there !
I have not yet begun to disassemble anything, but have done a little testing. (please forgive my layman's terms for the following parts). None of the linkage from the control lever to the control valve body seems jammed. The cylinder sticking out of the valve body that the linkage connects to seems jammed into the valve body. That is, it appears to be stuck in the fully depressed, DOWN position. Gentle prying upward will not free it.
Before I go tearing things all apart, I was hoping someone might know what's causing the problem and suggest a course of action. Also, if you know of anything to beware of when removing / disassembling the control valve body, I would appreciate hearing about it.
I can take some pictures and post them, if anyone would like to "SEE" the problem.
Thank you in advance for any assistance you can offer.
Tango
Tango
