I'm sure someof you have seen my threads over in the homemade section. Question I have to all and Tudor. My tank! I don't know if it is good or bad to have this tank under the seat. Has this been done before? It seams to be the best place I have to fit it to. Would the tank be too low for the sundstrand 15 pump to work right. There maybe space above and behind the engin head but I know the heat of the engine would not be good. The weight would be up hig there as well. So I kinder don't like that. Kinder don't like the tank in front of the raditor because the fan will draw heat thru the hot raditor. So I don't know what to do. I'm still a ways off from the part but I need to see a ahead picture in my head before I build something that won't work.
Eighter way I go which way should I install my in tank filter. Or does it realy mater. Kinder would like to run it up and down. I know most tanks I have seen use the filter side ways. Would it hurt to go up and down?
With this sundstrand pump will I need a holding valve or does the pump have a built in holding valve. If I would need a holding valve how would the valve work in my system. I know the Case tractors have a holding valve.
Sure could use some help here so nothing will go out the back door!
