1 - 3 of 3 Posts
Howdy! First question for me here. I own a Bobcat CT122 that needs a Hydraulic pump. Bobcat #7025277. The Sister tractor, Kioti CK20, pump number is #T2350-76103. Physically identical on the outside. Bobcat wants over a grand. Kioti wants around $500.00. Can I use the Kioti and save money? Thanx! in advance.:thanku:
If the displacements, pressure ratings, mounting holes, input shafts, and ports all match, yes.
Drill bits can adjust hole mounting positions and hole sizes and plumbing fittings can usually adjust for port locations. If there is a coupling involved, different shafts can usually be adapted.
The critical ones are high lighted.
1 - 3 of 3 Posts
