I borrowed a log splitter that had issues, I discovered the piston wouldn't retract so I disconnected it and gave it back to the owner, with it went some of my hydraulic fluid. A couple days later I went to use my bucket and the hydaulics were jerky, I figured I was probably low on fluid. I've only owned the tractor for a few months but have no record of previous maintenance so I figured no harm in changing the fluid. SO I drained it and filled it with 23.9L as per the manual I've got.
Now the hydraulics do nothing at all. I looked in the troubleshooting section of the manual and among the potential problems is "Hydraulic piston pump not primed" so I turn to the page that describes the procedure and it shows me a picture of something I can't find. It is the same place I would connect a pressure gauge but I can't find anything like it on my tractor.
According to the manual other potential problems are
low oil level - not likely as I just filled it
flow control valve binding
hydraulic pump low pressure
check valve damaged or worn
draft control or position control linkage damaged
unload valve or back pressure valve faulty
lift piston seals damaged
unload valve plug worn
Any one else have this sort of problem? What did it end up being?
