I work under the assumption that if a person put it together, then I can take it apart, if I have the same or similar tools available.
Hydraulic components (such as valve sets) are made so that they can be removed and installed in the field with a minimum of basic tools. "In the field" could be anywhere from the middle of the front yard to several miles back in the bush. Getting down to the components may take additional tools. The important part is to label the hoses as you remove them so they go on the new component in the same place or it won't work.
Cylinder work is a bit different because there are several methods used to lock the cylinder together. In many cases, little more than a pair of snap ring pliers will be needed to take a cylinder apart, and a set of dentil pics to remove the old seals. In other cases, a set of Allen wrenches, a large pipe wrench, and a heating torch may be on the tool list. When in doubt, post pics of the rod end of the cylinder and someone should be able to assist.
Basic tool list
- Set of open end wrenches (Imperial and/or metric)
- Adjustable wrench (or socket set)
- Pliers
- Set of Allen wrenches
- Pipe wrench
- Snap ring pliers with a variety of tips
- Hammer and a set of drift punches
- Set of dentil pics
- Flat blade screwdriver
- Heating torch
Also a plentiful supply of clean lint free rags for cleaning parts. With hydraulics, dirt of any sort is the enemy when components are opened
