1 - 1 of 1 Posts
Is there any easy way to get all the moister out of the system other than just draining and replacing the oil several times ( gets pretty expensive ) , what about the oil in the cylinders that is contaminated when you run them you are putting the contaminated oil back in the system you just put new oil into, my Question is there any to purge the hole system one time or do i have to bite the bullet and change and run three or fore times before it's clean by the way my tractor uses hyd trans fluid if that makes any difference ,,,,, Thanks Wolfhound
1 - 1 of 1 Posts
