Did you release pressure on the circuit(s) first?
Andreas
Andreas
I tried to pop it back with a screwdriver but couldn't. The couplers were full of crap but I got them cleaned out. I think it's got something to do with the valves inside...You need to physically push the tractor outside piece back,probably has trash around the outside,the way u decribed the ends sounds right.
No, not yet. I still have another month of mowing left to do so I need to keep the deck down low. I was told that I don't really need a lockout valve for the 316 since it has more pressure going up front than a 318. If I don't get a lockout valve, will adjusting the t-handle eliminate the need for a valve?Micheal,did you reset the t handle in the back so the rear cylinder won't work?
Ok, I'll keep that in mind.Stopping the cylinder from moving will be fine for the blade,the loader needs the lockout valve .I THINK
Good thinking. I thought I may have to try using different color-coded plugs so I remember which line goes where. Didn't take me too long to figure out that there isn't any pressure with the lines hooked up backwards :hide: Oh well. This is the first tractor I've owned with hydraulics.I'm a big fan of these coupler boots.
Not only do they keep the connections clean, but they also make it easy for this old boy to color-code the couplers on all my attachments (plow, blower, Buford Bucket, dethatcher, etc) so I don't hook them up backwards. The cost is totally worth the time and frustration they save IMHO.
John Deere Hydraulic Coupler Dust Plug - Black - M85099
Good thinkin'. Mine arrived yesterday with my complimentary beer cozy. I got two full sets of four different colors, for the 317 and the 318.I'm a big fan of these coupler boots.
