I have My dad's internatioal 354 tractor for the summer. The 3 point lift has always been jerky. He bought it used and has had it since the 80's
when you say "Jerky", do you mean it jerks up real quick?
If that's the case....then the hydraulic pressure is to high.
how is this corrected
You didn't state if I was correct in assumption.
If it jerks up really fast, then the pressure is too high.....if the pump has an adjustable pressure regulator, then throw a gauge on it, and lower it. If not, then you'll need to put one inline.
Or, it's built to lift some serious weight, and you're just not using the right implements.
