Last week when using the 3-point lift, I experienced a catastrophic failure of the hydraulic lift cylinder. The threaded end that attaches to the clevis end broke off.
It's MTD P/N 727-0159 (990A) or 727-159 (990). As this is no longer available from MTD, does anyone know of a suitable replacement?
I did a search for 1-1/2" bore, 4" stroke, 5/8" rod and found nothing. If nothing else, I'm going to attempt to bore out the rod and insert another threaded piece.
Any other solutions? BTW - how does this come apart to change the o-rings?
Thanks, Rich
Thanks, Rich
