1 - 3 of 3 Posts
i have a l3400 kubota 389 hrs. just started acting jerky power steering hard this has man. tranny bucket and 3 point also very slow changed filter ,fluid no better dealer said 950 for new pump any help?
You would have to take pressure readings. If possible visually check the pressure relief valve(usually a seat or check ball) and spring. it could be leaking past enough to slow things down but not enough to stop altogether. Just throwing a pump at it without troubleshooting it could be an expensive learning curve.
1 - 3 of 3 Posts
