1 - 16 of 16 Posts
I have been noticing large areas of brown patches (dead grass) on my lawn the last couple of mowings. First I thought maybe a gas leak, but no gas odor, then someone said it may be from the muffler.
They show up the next day after mowing, in the spot where I left the mower idling for 1-2 minutes.
Yup, it's likely heat from the muffler/exhaust. Had the same thing happen with my zero turn, when it would sit on the grass while I was emptying the bags of grass.
Just to follow up, the exhaust on my zero turn is about 8-10" off the ground, with the exhaust port on the bottom, pointing backwards (the "port" looks like the B&S screw on exhaust direction cover, like the one for this exhaust https://www.ebay.co.uk/p/Muffler-Exhaust-Bs494585-494585-5hp-Enigines-Genuine-Briggs-Stratton-Next-Day/2255439007?iid=183079699254&rt=nc)
It likely doesn't help that the cooling airflow over the engine goes downward, so at least some of it would blow down over the exhaust, then towards the ground.
I can confirm that with my Cub XT1 which may be similar (MTD) that I have the same issue with the heat from the muffler leaving brown patches. Took a few mows for me to figure it out, as I was thinking I must have spilled some gas or that it was leaking something.
Now I make sure to park it over the weeds or unwanted grass starting to come up through the gravel if I know it is going to be idling in place for more than a minute or so...
Had the same thing on my HQ tractor, crappy design...On the Husqvarna Rider the exhaust is high up at the rear so no such problems there.
Skickat från min iPad med Tapatalk
Ok the shield and muffler look great, or normal. One more check to make sure your engine isn't getting real hot (causing a very-hot muffler): Would you be able to remove the cooling shroud on top of the engine to look for any signs of a mouse nest on top of a cylinder? I would say just look for signs, but it isn't always obvious from just looking from the outside.
not quins. but sextuplets
since the exhaust is going forward it will not cause dead grass.. in the pic I see the deck near the bottom.. like the grass is scalped.. u may b mowin too low..
You didn't apply any Weed and Feed lately? That could cause brown spots. I have this weed that looks exactly like grass. This weed has a lime green color when it first comes up and usually in small 12 in diameter spots. When I apply my Scotts Weed and Feed, I notice it kills this weed that looks like grass. I see brown spots two days after I apply the stuff. I'm sure its not my muffler because that points out the side.
When your tractor is up to temp, park it and put your hand on the grass underneath the exhaust area and see how warm it feels.
I'm sure that it is heat from the engine causing the brown spots. There are lots of threads on this issue going back years. It's not limited to just one brand or model either.
Easy test... if it turns brown just where you stop for a while, it's not weed-and-feed. I don't use weed killer and still get brown spots if/where I stop. I say "if" cuz I learned not to stop in places where I don't want to damage the turf.
the guy that get my Saber fertilize his lawn this spring.. he used a broadcast type.. he had clumps in it.. they left brown spots..
That looks like the same muffler and and heat shield that was on my polan pro. Did the same thing to my yard until I put a new muffler on it.
Bob E did a lotta mods to his mower.. u can see them if u click on the last part of his posting.. it takes to a tread he started..
1 - 16 of 16 Posts
