That should work fine and the welding job is a lot better than anything I could do.
With the bagger bracket attached the hitch attachment hole is not able to be used to pull anything behind the tractor. With this modification I can pull a dump cart, or lawn roller etc...Maybe a little late but this says it is made for the Husqvarnas.
https://www.amazon.com/Universal-La...d569f6ce3e4&pd_rd_wg=8rBFw&ref_=pd_gw_cr_simh
