Hi, I've got a ******* Husqvarna 359 . it did have the dreaded walbro carb on it. since replaced with the zama . So it fires up pretty easy when cold approx. 3 pulls . Problem is restarting after its hot ?? I'm leaning towards a coil ?? Thanks in advance !
Paging @WrongDoug
Let's see if he can pop in and lend a hand here.
I'm here, I'm here! Hot start issues can be a couple things. Usually (but not always) related to carb tuning. Have you removed the limiter caps on the carb so that you can fully adjust the screws? It could be a coil, but I would be a bit surprised if it was. It can also be a compression issue, hot compression is always lower than cold and you may not have enough hot compression to restart. What do your piston and rings look like?
The 359 is a bad-a saw, mine is my go-to for the majority of my saw work.
Plant Tool Slope Grass Tree
The J-red version benefitted greatly to a muffler mod. The muffler was greatly restricted. Mine has had port work done and it does very well at the chainsaw races at the county fair.
  • Like
Reactions: WrongDoug
My muffler is gutted as well with an extra port on it. The Jonsered versions are always just a little bit cooler.
