What do you guys think about this? My 21hp kohler courage lost it's oil thru a bad output shaft seal and pretty much blew up. Now after really digging in on this engine I hear it's crap. So my plan is to swap in a B&S 21hp intek. Rebuild the kohler and sell it. The shaft size is the same, same keyway size and it's tapped the same. I'm not really to concerned about mounting holes I can make that work. My two questions I have are is the intek a good engine and where the **** can I find a B&S service manual with dimensions and such. Kohlers site is really easy to find all that info, B&S just has operators manuals. Also the B&S is also like $300 more expensive.
Here is the kohler
And here's the B&S
Or is there another comparable engine reasonably priced?
Here is the kohler
And here's the B&S
