1 - 2 of 2 Posts
After using my new,used , Kioti ck20 a few times I think the HST pedal is way too stiff . Fluid levels are all good, the 1 grease ftg in the pedal assy is greased. I have to use quite a bit of force to change direction and it seems to stick in place. Any suggestions??? Thanks.
Don't have a hst tractor so can help none,except to suggest you go over to tractorbynet,they have a kioti section,with many kioti owners,that like to talk alot about,[yeah you guessed it],kioti tractors!:drunkie:
1 - 2 of 2 Posts
