Welcome aboard tc25dnewholland.
As it is with just about everything, theres no single "best" at everything tranny for a tractor.
Alot depends on what your intended uses will be.
I think an HST is better suited for SCUTs & CUTs due to their primary usage being finish mowing. I have mowed w/an HST & gear tractor and I much prefer the HST for mowing.
A shuttle shift can't match the instant & effortless speed changes of an HST but it can match the directional changes which makes it just about equal w/an HST in FEL work.
Your arguments in the characteristics of the HST are spot on, you do have to ramp up the rpm and there is a loss of hp at the pto, when compared to a similarly sized gear or SS tranny.
i believe all the manufacturers make a gear tranny CUT model, I know JD, Kubota & MF does. Theres not a thing wrong w/prefering a gear/SS tranny over an HST. If thats what you want thats what you should get.
You are the one thats got to own & operate it
Dave
Dave
