"With the air filter off and I hold my hand over the intake I get a blow out and then a good suction as the piston rotates. Does this indicate a bad intake valve?"
That may be natural, hard to tell from here. The Compression Release bumps the Intake Valve open a few thousandths to relieve compression for starting on the compression stroke hence some blow back thru the carb. That should be followed by the power stroke, then the exhaust stroke, then intake suction. IF the suction comes immediately after compression stroke then perhaps the Intake valve is sticking OR the valves need adjusting.
I have detailed instructions for adjusting the valves IF you would like them. Address below, put in proper format.
Walt Conner
wconner5 at verizon dot net
Walt Conner
