1 - 3 of 3 Posts
i got the clutch and main nut off, but how do i pull out the whole flywheel and does it also have it's own thread that i should turn to get it loose?
i just need to get the rest of the case off to clean it from all of the sticky dirt
Discussion Starter · #2 ·
now i added some wd40 and tried to knock the shaft a bit and turn the flywheel counter-clockwise with some rope stuffed into the cylinder, but still didnt get anything loose...
ok nvm.. it probably sat in the wd40 a bit now and when i found a bigger lever to turn the flywheel by its clutch bolts, then it started to come loose and i got it off at last...
but the trick is to probably just wiggle the stuff around with the bigger lever a bit and not even try to turn it that much, because it has that flywheel key keeping it in the same position anyway...
or just use a rubber hammer on the edges then or smth...
1 - 3 of 3 Posts
