No one?
I'm not sure how far in the block the 4 pins press into the block. No way to tell that I can see, I would assume you put the block in the yoke and press the pins in as far as you can and then put the caps on and press it further till everything seals up and is flush with the yoke.Great update.
So the 4 pins press into the block. How far into the block and what depth? Is there a ridge in each hole that sets the depth of the pin?
Proper size dowel pins for new pins and new bearing cups from a u-joint. If the OD of the cups is a bit too big, the yokes could be bored to size, press fit. Looks like it could be rebuilt with the help of a machinist, hydraulic press and access to precision dowel pins that fit new cups. These are what William used.
Koyo M-661 Needle Roller Bearing, Drawn Cup, Closed End, Open, Inch, 3/8" ID, 9/16" OD, 3/8" Width, 7100rpm Maximum Rotational Speed: Amazon.com: Industrial & Scientific
https://www.mrosupply.com/product/1497077-M661-Koyo_Bearing
Shame on White/MTD for installing such a part that isn't user serviceable! You can see where the small roller bearing pins in the cap dug into the dowel pins and are worn. Not sure if its just wear and tear or if its from my nephew hitting a clothes line pole with it when my parents still had the tractor. The rear key on the drive shaft was broke as well, you would think it would have sheared it off. The tranny is also messed up and feels like it has a tooth missing at times. I bet it is all a result of him hitting that pole, but that was probably 8-10 years or so ago though so who knows.The style you have was not meant to come apart. I would find a shop near you that can build or rebuild drive shafts.
I had that same style in a Bolens 1669L. A local shop rebuilt it using a Weasler N6 universal joint.
Dave
The rear Oil Seal came out on the back of my motor on my White GT-1855 and sitting on the drive shaft. How can I remove the drive shaft? I don't have to take apart the universal joint to get it off do I?
I was hoping there is enough room just to move rearward, but doesn't look like it. Or you have to take the rear off first?
I think I had to take apart a universal joint on the 60" deck that I had and it had a bunch of small bearings that flew everywhere when I split it apart. I don't want to go through that again, I would assume the drive shaft is the same, which is why I don't want to split it apart if I don't have too.
Thanks,
Dan
