MT IDA
This is and older inverted 2 cycle engine. I am ready to install rebuilt magneto with no timing marks on anything. I need to know about how many degrees BTDC this should fire. It has no advance. I can time it with a degree wheel and make my own timing marks Just ball park figures would be fine. Thanks MT IDA
MT IDA
It should run ok at 10 or 15 degrees BTDC.:goodl:
Well I think you were correct. I degreed in the flywheel[under the hump in the engine] set the timing static, then used an inductive timing light from a battery with the neg. hooked to the engine to recheck it. Right on. Thanks. MT IDA
Branded for LIFE !!!
Nice ..Haf-a-horse.. Mt Ida..B,:trink40:
