Very true! I purchased a used Honda 3813 for $400 to act as a backup to my 2011 Cub Cadet. As is usually the case, about every four full mowing, the Cub has something (usually related to the mower deck) fail. This past Saturday, it was a carb problem with the Cub Cadet that I just wasn't in the mood to troubleshoot before the high heat of the day took hold. So out came the Honda..started right up and purred through the 4 acres of grass that hadn't been cut for 2-1/2 weeks. As usual, that little Honda didn't skip a beat.
The Cub? The non-starting was caused by the float being stuck closed. A rap on the float bowl and it fired right up. Maybe the Cub will run next week and if not, I know the Honda will be ready and eager to go!
