Picked up a Case 644 a couple months back, pulled the trans off today to do some maintenance and there's a weld on one axle
I know you can only tell so much by a picture, but I'd like some thoughts on the weld job.
The 644 is a fairly heavy garden tractor, iirc somewhere around 1500lbs. I could potentially have a hundred or two pounds in the weight box as well, so there's a decent amount of stress on it.
Thus far its been fine, should I think about replacing that axle or does it look good enough?
