I don't put the weight of the deck on the wheels. My wheels don't have bearings or grease fittings so I don't believe that they would hold up to prolonged usage under weight.
It depends on who made your equipment. Simplicity & Ingersoll have ground contour decks. Most others have suspended decks with anti scalp wheels like JD. slkpk
The manual for the JD 62C (23XX series tractors) deck specifically says that the deck is to be adjusted so the wheels are about 1" off the ground when in the mowing position. They are to keep the edges of the deck from contacting the turf.
This place (MTF) is amazing. I got a 318 a few months ago and was going to ask the same question as this. I guessed but was not sure. And here I go with answers before I even asked. Thanks you all.
Here is the actual manual text:
Adjusting Mower Deck Wheels
IMPORTANT: Avoid damage! The mower deck can be damaged if mower wheels are adjusted wrong: • Wheels must not ride on ground supporting mower weight.
• Check wheel adjustment each time cutting height is changed.
1. Inflate tires to correct pressure.
2. Raise mower deck to highest (transport) position and adjust cutting height.
3. Lower deck to mowing position.
4. Park machine safely. (See Parking Safely in the Safety section). NOTE: Bottom of wheels should be approximately 6-13 mm (1/4-1/2 in.) from the ground.
5. Pull gauge wheel release rod (A) and position wheel in correct hole (B). See decal located on deck.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
