So I've had somewhat of a friendly disagreement with someone about cooling procedures on air cooled engines. Someone had made a suggestion that turning the engine off at wide open throttle on a D series tractor will stop backfiring problems. Sure maybe it will but that IMO isn't a good remedy for the problem.
The only backfires I've had was when the engine was shut down while it was to hot. The remedy is to propery cool your engine before shutting down. For me that is running the engine at just under a half throttle for a minuet or so to allow cool airflow over the engine after a hot run of work. To back me up the X series owners manual explains to run at half throttle for a moment before shutting down. Why?...to allow cooling. Furthermore, the Kawasaki FH manual has a WARNING about shutting hot engines down that it can and will cause engine damage. Why....because a hot air cooled engine gets hotter after shutdown.
So after I explained this I was told to argue with the D series owners manual. What????? Why would the D series manual say any different??? I have a theory on why it doesn't but I will wait and see what you guys think the reason is first. I will say this though...the web is scattered with residential mower engine failures, cracked blocks, ect ect. Mostly Kohler courage and Intek engines. Could the lack of proper cooling techniques in their owners manuals and ill informed operators be the culprit?? Ill let you decide
